Ansys Learning Forum Forums Discuss Simulation Fluids Assistance with Automated Mesh Export Reply To: Assistance with Automated Mesh Export
ghislain_madiot
I'm planning to conduct a Design of Experiments (DOE), where for each design point, the following steps are executed:
  • Define the parameters.
  • Update the geometry accordingly.
  • Produce the mesh.
  • Run simulations using Fluent.
Currently, I specify the parameters using an external source, which involves scripting a journal file that Fluent will execute.
The challenge I'm facing is in automating the mesh generation process. While I can perform this manually, my goal is to streamline the task. If there's a more straightforward method or another software that simplifies mesh creation (ICEM?), I am willing to consider it. Any advice or alternative solutions that you could suggest would be greatly appreciated.
