Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Transonic Drag Under Predicted significantly › Reply To: Transonic Drag Under Predicted significantly
Compare your settings with the NACA example in Help. Also check the gas density is as expected. The most likely cause of error if the mesh is suitable are the reference values for the reports.
