Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Error messages ‘The demanded solver was not found in the specified path’ › Reply To: Error messages ‘The demanded solver was not found in the specified path’
April 11, 2024 at 2:52 pm
Ram Gopisetti
Hi wooju,
Please check the bin> win64 directory of your installed ansys version if it has lsdyna_sp/dp_/mpp/smp. exe files , if not , you need to make sure you install the software again with proper LS-Dyna features set or check with your IT .
Cheers, Ram
