Ansys Learning Forum Forums Discuss Simulation Electronics Analysis of Modeling Capabilities Reply To: Analysis of Modeling Capabilities
Ivonne Marti
Hi Kimmo,
In your last image, in concrete in the image column. I can see that you have warnings for the 0.001 and 0.01.
Warning: Major Mesh Repair -> Here you can try to use mesh operations to improve the mesh and/or try to test using the Classic mesh
Warning: Adaptive passes did not converge -> This is a clear message. You need to increase the number of passes. If the simulation does not converge then it is normal you are not getting accurate results. Please be sure your simulations converge.
I hope this helps.
Ivonne
