Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Setting Up the Periodic Pressure Drop as an Output Parameter › Reply To: Setting Up the Periodic Pressure Drop as an Output Parameter
April 10, 2024 at 8:58 am
I wonder if the report is linked to the conformal option. On older cases the periodic was a single boundary so getting a "pressure" on both ends wasn't possible whereas the nonconformal option has an interface at each end.Â
It worked on a test case here, but the report only triggered after running the model. Good spot, and it'll give the solution author something to do for a day or two! :)Â Â
