Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Structured O grid meshing issues › Reply To: Structured O grid meshing issues
Dear Federico,
The largest issue im still having is the weird unstructued mesh of the cone. With the multizone method it goes away but then the mesh at the interfaces between each section doesn't align.Â
I would to avoid copying the mesh as the distances of each section is slightly different which would change the streamwise cell length.
After I changed a number of parameters for the inflation layer I get the following layers. I am now only looking at the first section (the first cylinder).
This is the layers I want. However, the mesh has now changed to tetrahedral elements. Is this always the case as I had hexahedral elements at first?
(the image to the left is after meshing with inflation layer. Image to the right is without inflation and structured mesh I want)
Kind regards,
