Ansys Learning Forum Forums Discuss Simulation Fluids Setting Up the Periodic Pressure Drop as an Output Parameter Reply To: Setting Up the Periodic Pressure Drop as an Output Parameter
Did you use a periodic pair defined from the mesh or the non-conformal approach?Â
