Ansys Learning Forum Forums Discuss Simulation Electronics Magnetic Field Around A Current-Carrying Wire Reply To: Magnetic Field Around A Current-Carrying Wire
GLUO
Seems like a picture is missing here..The B field is affected by the current distribution inside the conductor. 2D desings only allow Z directional current, unless you would like to manually apply current at other directions, 2D is good enough to capture the AC effects.
GL
