Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Why did the middle section not get solved? › Reply To: Why did the middle section not get solved?
Mohammed Alhulaimi
Thank you I will try this tomorrow when I'm back in the computer lab.
I'm just wondering, when I use beam tool will it only solve for the stress in the beams or will it solve the whole model?
Also when I tried to solve for the convergence plot it said "Convergence is not supported for results in line bodies". Will using beam tool fix that problem as well?
