Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Why did the middle section not get solved? › Reply To: Why did the middle section not get solved?
peteroznewman
Was the middle section meshed with Beam elements on Line bodies?  You don't get an Equivalent Stress on Beams.  Insert the Beam Tool into the Solution to get stress results on Beams.
