Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Export values after simulation › Reply To: Export values after simulation
Assuming you have case & data over the duration of the run, yes it's possible. You'd need to export some position data and then work out the angle from that: there may not be an easy way to just return angle.
