Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Floating license activation errors › Reply To: Floating license activation errors
April 3, 2024 at 11:28 pm
Thank you for the instructions. We followed the 3 steps and on step 3, I am still getting a "server unreachable or licenses could not be found" when I use the optics launcher settings on the second computer.Â
When we use the ansys client setting to try to connect to the license server, a green check mark shows up after we click "test" (so that sounds like it was recognizing the license server). This wasn't the case before so it sounds like the firewall issue is solved?
