Ansys Learning Forum Forums Discuss Simulation Electronics Rotating object with fixed axis of rotation Reply To: Rotating object with fixed axis of rotation
NKC
Hi Anunda,
If I understand correctly, you only want to tilt the object by a few degrees but it is rotating more than 180 degrees.
Can you confirm if you are following the below process?
Select the objects you want to rotate, under the Draw tab select Rotate.
On the popup window select the axis and give the required angle of rotation,
Navya
