Ansys Learning Forum Forums Discuss Simulation Fluids Air water mixture entering a pipe from a stored chamber Reply To: Air water mixture entering a pipe from a stored chamber
Siddharth Shandilya
Determine the force necessary (energy required to operate the linear motor) to drive the linear tube within the cylinder under pressurized circumstances for a one stroke. (During the transition from the top position to the bottom position) and also energy required to operate the ball valve.
