Ansys Learning Forum Forums Discuss Simulation Fluids Using Dense Discrete Phase Model Injection Type Reply To: Using Dense Discrete Phase Model Injection Type
What fluid flow rate are you expecting/setting?  Please read up on parcel theory, with the injection you're adding parces not particles so a surface injection adds the mass you set split between the surface facets.
