Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Rotating object with fixed axis of rotation › Reply To: Rotating object with fixed axis of rotation
Navya Chode
Hi Anunda,
I did not understand what you meant when you said- " rotate the object in X and Y axis but want to fix the rotor at the centre point." Because if you rotate the whole geometry around X axis it will change the center.
What are you referring to as object, rotor and center? Please mark these on your image and elaborate on how you want your final model to look.
Navya
