Ansys Learning Forum Forums Discuss Simulation Electronics Animate Not working in Ansys Maxwell Reply To: Animate Not working in Ansys Maxwell
Navya Chode
Magnetostatic simulation is enough for your requirements.
Is the create animation setup window pop up when you right-click on the plot and select animate?
On this window select the appropriate parametric variable.
