Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › simplify faceted solid for adding obstruction › Reply To: simplify faceted solid for adding obstruction
Devendra Badgujar
Here is the quick summary of Adding Obstructions to the Original Artery Geometry | Ansys. Can you please let me know at which step are facing this issue as per the steps mentioned in the above course?
Instead of merge tool, you can use Fill tool to merge those faces and see if that helps.
Devendra
