Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How can I give different transmissivity with more than 3 wavelength region? › Reply To: How can I give different transmissivity with more than 3 wavelength region?
gopalakrishna.gangisetty
Hello Mr. Essence,
Thank you very much for the response. I am using semi – transparent material and its emissivity is 0.25 for Long wave radiation, Refractive index is 2.2. I followed the instructions given by you. In the radiation tab, There is an option called beam direction where the default is X = 0, Y = 0 and Z = 1. I have an acceleration due to gravity set in Y direction = -9.81 m/s2. Then What is beam direction. Should it be X = 0, Y = 1 and Z =0 or X = 0, Y = -1 and z = 0 given the Y = acceleration due to gravity = 9.81 and this application for natural convection ?
Please kindly help me.
