Ansys Learning Forum Forums Discuss Simulation General Mechanical User-defined hyperelastic material model for workbench structural simulation Reply To: User-defined hyperelastic material model for workbench structural simulation
SSURA
Hi Eric,
Please check the following link to explore different nonlinear material models offered by Ansys -  https://ansyshelp.ansys.com/Views/Secured/corp/v232/en/ans_str/Hlp_G_STR8_3.html
Considering the complexity of the material model, you might achieve this by running separate simulations for tension and compression, each with its material model, and then combining the results.
Please check the following references for more insights -
/forum/forums/topic/using-experimental-material-properties-in-structural/
Hope this helps!
Thanks,
Sahil
For more exciting courses and certifications, hit this link: Ansys Innovation Courses | Ansys Innovation Space
If you are not able to open the links, refer to this forum discussion: How to access the ANSYS Online Help
