Ansys Learning Forum Forums Discuss Simulation Fluids phase change hydrogen in heat exchanger Reply To: phase change hydrogen in heat exchanger
jackzhe551
in the heat exchanger design,1. How to set the dynamic physical properties of phase-change hydrogen? Can refprop be invoked, and how? Can you give a tutorial of a phase change heat transfer case? (hydrogen varies in temperature from 15K to 50K, while 15-33K is a liquid and above 33K is a gas) 2. Once the refprop is set, is the rest of the operation consistent with the non-phase conversion thermal operation process? What should I pay attention to? 3.the case is one channel goes turbulent air,another channel is the phase change hydrogen 4.can air  turbulent model and vof model of hydrogen set in fluent simultaneous?how?
