Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Update failed for the Solution component in Fluent. Update Solution Failed › Reply To: Update failed for the Solution component in Fluent. Update Solution Failed
March 5, 2024 at 7:00 am
Sorry to bother you mr RM, i solved the problem!! the reason is i think,, i should add the fluent tab(not fluid flow(fluent) tab) like below picture. and after loading the case and data file to the fluent tab, i run the calculation just 5 time, and then the green tick made on the solution,
and everything went well
Thank you for helping me, have a good day!!
