Ansys Learning Forum Forums Discuss Simulation General Mechanical Update failed for the Solution component in Fluent. Update Solution Failed Reply To: Update failed for the Solution component in Fluent. Update Solution Failed
Rahul Mule
Click on no while loading case and data, you'll get an updated solution cell. Connect it to Setup of mechanical for importing data from fluent solution.
