Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Update failed for the Solution component in Fluent. Update Solution Failed › Reply To: Update failed for the Solution component in Fluent. Update Solution Failed
March 4, 2024 at 10:21 am
This way is also correct. Load your case and data in Fluent and connect Fluent solution cell to Static structural setup cell to import load.
