Ansys Learning Forum Forums Discuss Simulation General Mechanical Update failed for the Solution component in Fluent. Update Solution Failed Reply To: Update failed for the Solution component in Fluent. Update Solution Failed
ydlee
hi. mr RM, i handled the green tick by just clicking the solution tab with right button and import the final data
However, the other problem occurred,,, you can see the below picuture, there is a problem in imported Load
