Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Low heat generation due to thermal runaway reactions when adding combustion › Reply To: Low heat generation due to thermal runaway reactions when adding combustion
February 8, 2024 at 2:12 pm
Murari Iyengar
Hi, the two models you are using are incompatible with each other.
