Ansys Learning Forum Forums Discuss Simulation Fluids Writing and reading profiles in Fluent Reply To: Writing and reading profiles in Fluent
javat33489
Sir. I have another problem. And I didn’t find the answer in the tutorial.
1. In the mesh, I added the name selections I needed for writing and reading profiles. These are two plates and in the nasoya this is the end of the second wheel and the beginning of the first:
2. In Fluent, these named selections are included in the interfaces section:
For recording, I was able to select the desired surface (2) and create a data recording profile file.
How can I specify reading from the written profile file (2) for profile (1) in the following calculation?
I planned it this way: first I write data from profile (2), carry out 250-300 iterations when all the graphs converge, then I stop the calculation and set reading from the profile file (2) for profile (1). I start the calculation again and profile (1) will begin to receive data from the recorded file.
But I can't set the reading for profile (1). How to do it?
