Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Multipoint path with Python › Reply To: Multipoint path with Python
erik.kostson
Hi
Whataver you do manually in Mechanical (create paths say using points or edges, etc), we can do with scritping also. So scripting basically automates anything done manually & repeatedly in the Mech. UI.
So if you can create the paths manually using the edge,two points or x axis intersect options (these are the only ones available in mechanical), we can also use scripting to do the same.
All the best
Erik
