Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › Solve Button Greyed out › Reply To: Solve Button Greyed out
January 8, 2024 at 4:12 pm
Hi Theresa,
You can try solving the model again. You can try updating the fidelity and then solving it. Would you please also check the messages as there might be some error due to which your solution isn't being processed?Â
You might also want to check if the geometry is completely defined.
Hope this helps!
Thanks,
Sahil
For more exciting courses and certifications, hit this link: Ansys Innovation Courses | Ansys Innovation Space
If you are not able to open the links, refer to this forum discussion:Â How to access the ANSYS Online Help
