Ansys Learning Forum Forums Discuss Simulation General Mechanical A solver pivot warning or error has been detected Reply To: A solver pivot warning or error has been detected
sahil.sura
Hello Calvin!
Considering the warnings/errors, I would recommend you validate the geometry first! As there might be a presence of some underdefined beams.
Solver pivot error to make you understand simply is the solution which has resulted in to singular matrix i.e., it may have many solutions (not unique) or is indeterminate.
There might be several reasons for this,
Underdefined material - Like improper density, material properties, etc. (Maybe in this case)
Underdefined geometry (Maybe in this case)
Improper constraints - Over or under constraints
Underdefined Contacts
Buckling (Maybe in this case) - Structure is deforming up to the extent of giving a non-unique solution.
How to deal with this issue -
Check and verify the above-mentioned points or if you're getting the apt result and post-processing is an issue, turn off the solver pivot from 'Solution' or Lapse the solver pivot checking using the command (PIVCHECK, OFF - PIVCHECK (ansys.com) )
References -
5.9. Singular Matrices (ansys.com)
Search Ansys Documentation
A solver pivot warning or error has been detected (ansys.com)
Error: Solver pivot warnings or errors have been encountered during the solution (ansys.com)
Hope this helps!
Thanks,
Sahil
For more exciting courses and certifications, hit this link: Ansys Innovation Courses | Ansys Innovation Space
If you are not able to open the links, refer to this forum discussion: How to access the ANSYS Online Help
