Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Problem in initialization patching › Reply To: Problem in initialization patching
You may find it to be safer to patch the volume fraction of phases to be zero and then patch to the desired values, ie 0.59, 0.205 and 0.205  The solver should scale the values back to a sum of 1, but the warnings still trigger. You may also need to turn off the smoothing (bottom left of the panel).
