Ansys Learning Forum Forums Discuss Simulation Fluids Problem in initialization patching Reply To: Problem in initialization patching
SRP
In the image it shows primary phase as phase B and the problem description it is mentioned that phase B as secondary. I consider primary phase as Phase B based on that I suggest you to initialize domain with primary phase then patch the secondary phase on the mark domain.
Hope this helps you,
