Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › An internal solution magnitude limit was exceeded. › Reply To: An internal solution magnitude limit was exceeded.
Tadeáš Salcman
I tried to do the normal stiffness factor modification to 0.1 but it didn´t help. Here are the contact settigs:
And solution information:
What should I try next? Thank you for your patience with me :)
