Ansys Learning Forum Forums Discuss Simulation General Mechanical An internal solution magnitude limit was exceeded. Reply To: An internal solution magnitude limit was exceeded.
Akshay Maniyar
It looks like the residual force is not converging. Can you try using the Normal stiffness factor as 0.1 for the contact you mentioned and see if it helps?
Thanks,
Akshay Maniyar
