Ansys Learning Forum Forums Discuss Simulation General Mechanical An internal solution magnitude limit was exceeded. Reply To: An internal solution magnitude limit was exceeded.
Akshay Maniyar
It is great that you were able to find the issue. Let it run completely and see what is the error message and why it is failing. It will not be because of rigid body motion. Rigid body motion issue generally happens at the start only. It can be because of high force residual or element distortions.
Thanks,
Akshay Maniyar
