Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Need help with V-bending simulation with Ansys › Reply To: Need help with V-bending simulation with Ansys
Vincent Doan
Thank you for your suggestion. It went quite well. But the thing is, my sheet metal plate is too flexible, felt like rubber, is there anyway i can make it bahave like normal steel plate? And also, i want to input the force at the end of the journey, is it possible?
Thank you
Vincent
