Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › An internal solution magnitude limit was exceeded. › Reply To: An internal solution magnitude limit was exceeded.
Akshay Maniyar
Thanks for the update. Are you still getting the rigid body motion error? You can model the bolts as beam connections if they are not the primary concern. From the contact tool table, it looks like there is a gap between the washer and the nut. Can you try using the quasi-static solution option and see if it helps?
Thanks,
Akshay Maniyar
