Ansys Learning Forum Forums Discuss Simulation General Mechanical QUERY ON CONNECTION BETWEEN SHELL TO SOLID ELEMENT AND SHELL TO SHELL ELEMENT Reply To: QUERY ON CONNECTION BETWEEN SHELL TO SOLID ELEMENT AND SHELL TO SHELL ELEMENT
peteroznewman
Did you build a model entirely with solid elements and no shell elements?  You can use Shared Topology if you need to change properties between the middle and the ends of the tube. Just make sure to use at least 4 linear element or 2 quadratic elements through the thickness.
