Ansys Learning Forum Forums Discuss Simulation General Mechanical No plastic deformation in Explicit Dynamics on a Beam Section Tubular Chassis. Reply To: No plastic deformation in Explicit Dynamics on a Beam Section Tubular Chassis.
Armin
Hi David,
It appears that the ends of your beams are not sharing a node. Please check if this helps: Once you have created all the line bodies in SpaceClaim, highlight selected parts under the part tree, right-click and select Move to New Component. After specifying a cross-section for the line bodies (in the Prepare tab), go to the Workbench tab, and select the Share object. The nodes at the coincident regions should be merged (shared topology).
You can also try creating Bonded contact within Mechanical but you may try the approach above first.
