Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Component systems not showing in structures package › Reply To: Component systems not showing in structures package
Rajeshwari Jadhav
Are you able to ping or telnet your server, in the command prompt try using cmd “ping servername” and “telnet servername 1055”?
 To ON telnet service go to start and search “Turn Windows feature on or off” check box “Telnet Client” and click ok.
 Go to the start menu, open the command prompt, and run the below-mentioned commands:
  1. ping servername
type this command and send the screenshot of the output.
  1. telnet servername portnumber
A blank screen will confirm that you are connected, if you get any other output, please provide a screenshot of the same.
