Ansys Learning Forum Forums Discuss Simulation Fluids modeling heat transfer considering thin wall separating two fluids Reply To: modeling heat transfer considering thin wall separating two fluids
You may need to add daat fields to the cdat file, not everything is transferred and some fields are calculated in the Fluent solver as needed. We post process mostly in Fluent too: CFD Post use for Fluent is far less common than 4-5 years ago.
