Ansys Learning Forum › Forums › Discuss Simulation › Electronics › 3ph Wound rotor induction motor maxwell 2D › Reply To: 3ph Wound rotor induction motor maxwell 2D
November 24, 2023 at 3:34 am
Hello Mahfoud,
      The connection is fine, but can you please connect -ve terminals of sources to single ground. Please check the phase voltage magnitude and frequency.Â
Thank you,
Harinath Vudumula.
