Ansys Learning Forum Forums Discuss Simulation General Mechanical Transient Analysis Residual Vibration Reply To: Transient Analysis Residual Vibration
Ankush Choudhary
Hi Gioele,
If you apply the displacement to fixed supports, then it will only give zero displacement as those faces are already fixed in the modal analysis. You may give displacement at some other surface or try to apply an acceleration load.
