Ansys Learning Forum Forums Discuss Simulation General Mechanical A general failure occurred during the solution process: Reply To: A general failure occurred during the solution process:
Akshay Maniyar
Hi Ermias,
Can you try to reset the Ansys settings by using the following steps?
  1. Close all Workbench sessions.
  2. Type %appdata% in the search field of Windows.
  3. Open the folder named Ansys.
  4. Locate the folder corresponding to your installation, for instance, if you are having an error with R19.0 installation, then locate the folder named v190 (similarly, locate v191 for R19.1).
  5. Rename this folder as v190_old and start a new WB session.
This will create a fresh copy of the v190 folder (which contains WB environment files) and resolve such issues. The procedure is the same for different versions of WB so you just need to rename the appropriate folder.
Thanks,
Akshay Maniyar
