Ansys Learning Forum Forums Discuss Simulation General Mechanical ANSYS Workbench Failed Mesh Reply To: ANSYS Workbench Failed Mesh
Govindan Nagappan
Check the geometry and if there is intersection in geometry, you will have to fix it before importing into Mechanical.
If there is no intersection in geometry, then locate the area where you have intersecting mesh and reduce the mesh size locally to capture the region.
You need to identify the problematic location
