Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Ls-Dyna Restart repeated many times › Reply To: Ls-Dyna Restart repeated many times
camilla.gironi4
Hi Ram, thank you for your suggestion!
The wires need to be inserted in sequel, so each wire will interact with the previously deployed wires. Is it possibile do model with the dynain file you mentioned? Sorry but I've never used dynain files before
thank you again
Camilla
