Ansys Learning Forum Forums Discuss Simulation LS Dyna Ls-Dyna Restart repeated many times Reply To: Ls-Dyna Restart repeated many times
Ram Gopisetti
Hi
With simple restart or with any restart type, you cannot add geometries in the LS-Dyna workbench.
Think again if you are considering the full restart, as it penalizes the computation time and efficiency.
Instead, use the DYNAIN file method to do sequential analysis.
It depends on how these ten to twenty wires are inserted in sequel or in one go.
Cheers, Ram
