Ansys Learning Forum Forums Discuss Simulation Photonics Why the transmission power is continuously reduced along the structure in FDTD? Reply To: Why the transmission power is continuously reduced along the structure in FDTD?
Dev
Hello, Thanks for using the forum.
Can you share a bit more deatails:
Source used, type of monitor, length and width of device.
Have you tried material fitting before running simulation?
Thanks and regards
Devika
