Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Making a hole on a pipe › Reply To: Making a hole on a pipe
YH
I would like to make a geometry like this. So the fluid domain should be generated as if there's a hole in the pipe. But the outlet protrudes slightly from the pipe (figure above). Would you tell me how to make the fluid geometry?
