Ansys Learning Forum Forums Discuss Simulation Fluids Multiphase Eulerian-Eulerian PBM DQMOM – Setup Reply To: Multiphase Eulerian-Eulerian PBM DQMOM – Setup
DrAmine
Yes you can deploy DQMON for that purpose. The 3 solid phases will build the dynamic system of your solid particles so in every cell which allows solving the quadrature. You must see the parameters of the 3 solids phases to be same: they all are referring to same material.
